Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Towbar options / comments
    SOC Member
    Jun 2012
    Dumfriesshire UK
    47
    Hi,
    I'd like to fit a towbar.
    Rimmers at 200 inc or Watling ( www.watling-towbars.co.uk/ ) at 144. Both inc VAT but ex delivery.
    Anyone have any comments / reviews / ratings on either of the above two or perhaps know of another source entirely?
    Thanks in advance
    David
    David Kirk
    1972 Manual O/D - Damson, 1975 Maual O/D - Mimosa
    My car now in Florida outside my watering hole.... malc4d's Avatar
    May 2013
    Orlando Sanford
    1,258
    I have 2. On the Rimmers one that l bought about 4 years ago, I found that the main bar that goes across from the left to right bumper fixings was not bent out enough so it just touched the rear of the car. I should have sent it back ! The other cars bar fits so much better. But l bought that in 1986 so don't ask me who made it ..... :-)
    Also as a small tip.
    Buy a pre wired extension socket, cut off the plug and wire it up so that it lays in the boot and can be poked out of boot when needed. This will save drilling holes into the rear of the car.
    http://www.ebay.co.uk/itm/7-Pin-Trai...MAAOSwGy5Y8KVM
    SOC Member, TSCD Member, Moderator dasadrew's Avatar
    Dec 2009
    Nr. Submuntorium, Germany
    5,424
    On the subject of putting towbar related things in the boot, I always have a 7-pin / 13-pin adapter on board unless you know that it is always going to be the same trailer / cycle rack etc., which you will be using and not a hired / borrowed one.
    Drew
    If you can't say something nice, don't say it !
  4. #4
    Taking it slow in 2017 mole42's Avatar
    Feb 2015
    Bristol, UK
    1,820
    There are often second-hand ones offered in the For Sale section. Mine was 50, fits properly and works well.
    And I got to meet another decent Stag chap!
    Mabel is a white 1972 Mk1, TV8, ZF 4HP-22 auto,
    2016 RBRR finisher.
    SOC Member v8ken's Avatar
    Nov 2011
    South Yorkshire/Gozo
    305
    Yes,I'm looking for one at the moment,these have them also-
    https://shop.tssc.org.uk/product/tow-bar-stag-ptr29
    Ken.
    ps. Rimmers do 'price match' on parts as well.
    SOC Member mjheathcote's Avatar
    Mar 2007
    Holmfirth, United Kingdom
    2,412
    Quote Originally Posted by malc4d View Post
    Good idea that!
    74 Triumph Stag (Best Modified 2007), 02 Maserati Coupe Cambiocorsa.
  7. #7
    SOC Member
    Jun 2012
    Dumfriesshire UK
    47
    Hi Ken.
    That one from the TSSC is made by Wattling. But at least there is a photo of it.
    Anyone fitted one?
    David Kirk
  8. #8
    May 2013
    Orlando Sanford
    1,258
    Yup Drew. l did that, but then l have lived in Switzerland where they also use the 13 pin system. Its been very slow to take off in the UK but is available. I fitted the 13 pin and have an adapter to 7 pin.
    Also the 13 pin if fitted must work for an MOT !! not the 7 pin ??
  9. #9
    vented disc member new to this's Avatar
    Feb 2010
    Stag mk2 manual overdrive harrow middlesex, , United Kingdom
    5,086
    Theres a tow bar on ebay at the moment
    73 mk1.5 originally mimosa now gone to the dark side Delft Blue 73 white soon to be blue
  10. #10
    SOC Member Dave M's Avatar
    Feb 2007
    Lincoln
    2,091
    I got mine from Rimmers, fitted Ok but is uglier than some others I've seen. As I don't use it very often these days I welded the fixings nuts to the boot floor and remove it when it's not needed. To re-fit it I just simply bolt it back into place. The bit behind the bumper obviously stays on the car permanently.
