Results 1 to 5 of 5
Thread: How do I fit hardtop?
    SOC Member CV35Ian's Avatar
    Sep 2014
    Kineton, Warwickshire
    124
    So after three years of owning car, decided to fit Hard Top so I can move car and roof to new garaging.
    So questions.....
    1. The side clamps are about quarter of an inch too high to locate in their holes and therefore can't clamp roof in place
    2. The rear pin won't stay in the retaining hole - all fine with new soft top.
    Front clamps locate fine.
    Any tips?
    Also, the front chrome trim needs refitting as its never been on there, tried marrying this up to the top but can't see how to rivet it in place as there's no cleArance inside.
    So that's the second bit of help needed.
    Thanks
    1973 Stag 1983 Porsche 944 2006 BMW R1200GS
    2008 Skoda Octavia VRS plus bicycles
    SOC Member Arbman Al's Avatar
    Mar 2008
    West End, Woking, Surrey, United Kingdom
    3,822
    I've removed the rear pin on mine. You might find the side clamps locate better then.
    1975 Mk2 3.0 V8 MOD, strommies, tubulars & quad exhaust = 150.8 bhp
    Taking it slow in 2017 mole42's Avatar
    Feb 2015
    Bristol, UK
    1,641
    According to the ROM, the rear fixing should be locked in first, then the B posts, then the screen top. (76.61.01)
    It's best to use all five fixings if you are planning to fit a roof rack or do some extensive motorway driving, the 'B' post fixings are not well secured to the body.
    Front trim is fitted with small plastic clips, available from the usual suspects. Not an easy or enjoyable job.
    Mabel is a white 1972 Mk1, TV8, ZF 4HP-22 auto,
    2016 RBRR finisher. 2017 10CR cancelled :-(
  4. #4
    Retired, and loving it...... DJT's Avatar
    Nov 2006
    Devon, United Kingdom
    11,596
    When I restored my hard top back in 2003 it wouldn't fit at first. I couldn't get the side fixings to sit down far enough. I used a ratchet strap attached to each subframe mounting and run over the roof. Tightened it and pulled the top down until the handles would turn. Had to do this for the first couple of pre-winter fittings, but eventually it would fit without once the seals had become formed to the right shape.
    1974 Mk2, Carmine, ZF 4HP22 Auto, 3.45 Diff, Datsun Driveshafts.
    Sep 2014
    124
    All very helpful thanks,
    I'll report back if/when successful
