Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Car running hot
    vented disc member new to this's Avatar
    Feb 2010
    Stag mk2 manual overdrive harrow middlesex, , United Kingdom
    4,968
    Car running hot
    Been out today in my brothers car,the temp gauge got to just before the red,stayed there,checked for leaks none found,radiator is okay full fan blade is okay,turned heater on just in case air lock,still no change to temp gauge,would it be because its a hot day,only other thing i can think of is could it be a faulty temp sender
    Any ideas thanks Dave
    73 mk1.5 originally mimosa now gone to the dark side Delft Blue 73 white soon to be blue
    77 TV8 Auto Stag Owner from 7/94 Tdm's Avatar
    Feb 2007
    Lancashire, Cheshire, North Wales;- then - Los Cristianos, Tenerife from 2004 to present day:
    3,822
    Quote Originally Posted by new to this View Post
    Shouldn't be the weather - I regularly drive mine with temperatures in the high 30s, 40s, even when it has touched 50 degrees Celsius one day last August.
    SOC Member
    Oct 2014
    Cambridgeshire
    1,145
    Assume your brothers car is a Stag?
    H
  4. #4
    Feb 2010
    4,968
    Quote Originally Posted by HersnotHis View Post
    H
    H
    Yes it is a stag
    Feb 2010
    4,968
    Quote Originally Posted by Tdm View Post
    Terry
    Thanks his car never normally runs hot,so looks like some thing must be wrong
    Thanks dave
    SOC Member
    Aug 2007
    8,886
    Instrument voltage stabiliser? Is the fuel gauge being a bit optimistic too?
  7. #7
    Feb 2010
    4,968
    Quote Originally Posted by kryten View Post
    Russ
    No fuel gauge is normal,would i be right thinking faulty temp sender ?
    Thanks dave
  8. #8
    SOC Member Arbman Al's Avatar
    Mar 2008
    West End, Woking, Surrey, United Kingdom
    3,822
    Russ
    Thanks dave
    Buy the one from LD Parts, as it is the correct one - only 7 so worth trying this first. food to see you yesterday Dave.
    Cheers...Al
    P.S Don't drive it so fast!!
    1975 Mk2 3.0 V8 MOD, strommies, tubulars & quad exhaust = 150.8 bhp
  9. #9
    SOC Member StagnJag's Avatar
    Sep 2007
    Dartford, Kent, '77MKII, MOD,TV8, , United Kingdom
    5,544
    Given the heat yesterday, I'd wait until the weather cools down a bit, take it for a run then and see if it behaves as normal. If it does, then it was the heat yesterday that did it. Mine was running a touch warmer than usual yesterday.
    If the temp was significantly higher then it is likely to be something else.
  10. #10
    SOC Member Jeff's Avatar
    Oct 2009
    Sonning Common, South Oxfordshire., , United Kingdom
    5,890
    Mine runs normal in this heat.
    They are out there and unfortunately they walk amongst us - beware!
