Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Brake squeal
    SOC Member Stokiestag's Avatar
    Apr 2017
    Blurton
    28
    Brake squeal
    At my wits end with constant brake squeal.Ive read loads on here about it but everything I've tried thus far has made no difference.It had a slight squeal when I purchased the car 6 weeks ago so decided to fit new pads/pins and clips with the anti squeal shims.Did that applied with liberal amounts of copper grease and that basically did nothing.Took the shims out yesterday and now it's even louder and more extreme.Any more thoughts on the matter would be extremely and gratefully recieved.
    Cheers Mark
    SOC Member Donkey's Avatar
    Jul 2015
    France
    280
    Quote Originally Posted by Stokiestag View Post
    Cheers Mark
    Hi Mark,
    I had the same problem following a replacement of the pads and sought help here.
    I ended up taking it all apart and "slapping on" more of the copper slip and apart from a few squeals around the tight mountain roads of Switzerland, at the ESM, the problem has gone.
    But if you had a squeal before your change maybe the issue lies elsewhere.
    Good luck anyway.
    My car never breaks down, it just occasionally fails to proceed.
    Retired, and loving it...... DJT's Avatar
    Nov 2006
    Devon, United Kingdom
    11,511
    Try chamfering the front and trailing edge of all 4 pads. This can help.
    1974 Mk2, Carmine, ZF 4HP22 Auto, 3.45 Diff, Datsun Driveshafts.
  4. #4
    Apr 2017
    Blurton
    28
    Dave,I fitted mintex pads and they were already chamfered on both edges,a bit too much for my liking.Think I might have sorted it now,took the mintex off and refitted the original ones ( looked like new anyway) and fitted the shims with plenty of copper slip on em.Theres a slight amount more play with these ( mintex were very tight) ,took it for a20 minutes blast and quiet as a mouse.FINGERS CROSSED.
    SOC Member Kithmo's Avatar
    Feb 2017
    Rotherham
    70
    There was another post on here recently about grinding/filing the edges of some brands of new pads to make them fit better (looser ?).
    SOC Member Jeff's Avatar
    Oct 2009
    Sonning Common, South Oxfordshire., , United Kingdom
    5,813
    It doesn't make them 'looser', it takes off the leading edge.
    They are out there and unfortunately they walk amongst us - beware!
  7. #7
    SOC Member wilf's Avatar
    Nov 2011
    Leicester
    3,133
    The metal backing, not the pads. I recall a FM with issues around "red stuff" pads that were resolved by relieving the metal backing of the pads a little.
    The trouble with getting old is that the future isn't what it used to be. - Bob Monkhouse.
  8. #8
    Feb 2017
    Rotherham
    70
    Quote Originally Posted by Jeff View Post
    Sorry I meant the edges of the metal backing plate, to make them fit easier into the caliper.
  9. #9
    Oct 2009
    5,813
    Quote Originally Posted by Kithmo View Post
    And I meant the rear shoes, must read first post properly.
  10. #10
    Feb 2017
    Rotherham
    70
    LOL, this post is turning into a two Ronnies sketch.
