Subsequent to the “Fire!” Thread previously posted, here is an update on the restoration process.
After the Insurance go ahead, the engine and gearbox unit was stripped from the car as the fire damaged bulkhead pad had to be renewed. All ancillaries were also stripped out from the engine compartment as it had been agreed that everything forward of the chrome scuttle air intake to the slam panel would have to be re-sprayed. The bonnet would be re-sprayed and a new bonnet pad fitted. New hoses, brake lines and cables were needed and the fire damaged Strombergs replaced. A new distributor and ignition system was also required. At that stage, I decided to bite the bullet and replace, at my own expense, the Brake Servo, Clutch Master & Slave Cylinder, and the Power Steering hoses. Additionally, as the gearbox was already out it seemed wise to replace the Clutch which was of unknown age.
Once everything was stripped out, the car spent two weeks at the paint shop getting the 2-pack Brooklands Green treatment. This was good news, as the engine compartment was still finished in the original factory Sienna Brown – even though at one stage he had been Pimento Red! In the interim the large parts order had been placed and the Strombergs sent away for reconditioning or replacement units. On return from the paint shop work started on reassembly. The new choke cable, from the main supplier of parts, was found to be “seized” and a replacement obtained before the Strombergs were fitted on 6th July. The Strombergs were defective in that they were leaking copious quantities of fuel from the lower brass fitments. This was totally unacceptable considering that it was a fuel leak that caused the fire in the first place! Carburettors returned and were replaced on 17th July – they were leaking again, this time from the left hand body. Frustration all round as the garage had now fitted two faulty sets of carbs from the same supplier. It was decided at this stage to reject the Strombergs completely. A set of Webers was organised – what a difference! Easy installation, no leaks and Nigel returned on 22nd July – he now carries a Fire Extinguisher!
In rejecting the Strombergs, I decided to check with Trading Standards (Consumer Advice) as to what my rights were regarding two lots of £26.10 return carriage to the supplier. Apparently under the Direct Selling Regulations the seller is responsible for carriage returns for faulty items– not the buyer. Additionally as I had incurred fitting and removal costs for the faulty Strombergs – the insurance would obviously only pay for the supply and fitment of serviceable items – I would be entitled to claim for “Consequential Loss” under the Sale of Goods act 1975.
In the event that any other owner has to go through a similar experience - I sincerely hope not – be prepared for delays and frustration along the way. Now I am a very “Happy Bunny” enjoying the unique Stag experience once more.
Alex
Alex
