    Strange question l know but does anyone know the PCD of the Stag?
    Let the head scratching commence.
    Assume you mean the road wheel stud pcd. 114.3mm with no scratching
      Lmao well done Koy, and thank you.
      l’d like some alloy wheels but there’s only the MK 2 alloys which isn’t much of a choice, and as there are plenty of alloys for sale (and lets face it the choices are endless) l thought if l knew the Stag’s PCD l could go shopping for some nice alloy’s.
      l should mention l have a 71 MK1 with steel wheels.
      Gaz
        You may need to keep an eye on the offset, particularly if going for bigger wheels/ tyres. Think a search will reveal lots of discussion on this aspect. From memory (suspect!) this may be termed "ET".
        Jonno
          Thanks for the heads up Jonno.
            Don't mention minilite replicas.
              I think they look great, although my Wolfrace slots look better
                Good Website that gives you an idea of which cars have the same PCD as the Stag - As mentioned watch the off set or you could always use spacers if its pretty close.
                Std Off-set is 28mm
                http://www.wheelfitment.eu/PCD/4x114.3.html
                Gary
                  Thank you for the info GT.
