Just thought I'd make a note of this. When fitting Luminition Ignition the instructions for the optical plate aren't that clear.Turn the dwell adjust clockwise until the chopper is a mm or so back from the optical arangement then clip down the wires. But use two cable ties rather like a saddle and girth. These wires are fragile and can get caught up in the spring and damaged. Also on the base plate there is a spring and nut / washer thatretains the base plate. The thread on this can contact with the chopper, so I ground about 2mm off to gain plenty of clearance.
What a difference Electronic Ignition makes. Just got the carbs to sort now. Where's that Bank Holiday Gone?
