VR1 valvoline
    VR1 valvoline
    Where are we buying it from now guys at reasonable price ? Cheers Graham
    I used www.opieoils.co.uk with code xbox10 I achieved 20liters for £102.55 inc vat and delivery that was 30th March 2018.
    It was mentioned on the post which engine oil do you use #46
    Cheers Glenn
      Xbox10 has expired :-(
      Does anyone know a valid code?
      Mabel is a white 1972 Mk1Ĺ, TV8, ZF 4HP-22 auto,
      2016 RBRR finisher. 400 mile C2C 21/22 April 2018!
        Www.dontpayfull.com then type in opieoils
        Chees Glenn
          This is the cheapest I can find it.
          Valvoline VR1 Racing 20W-50 Highly Refined Engine Oil 10L (5L X 2). VR1TM Racing Motor Oil SAE 20W -50. Washing Water. Free Screenwash Tablet S ufficient for 5 Litres of. Premium quality conventional motor oil. | eBay!
            Thx guys , regards Graham
              Does Valvoline VR1 have the required levels of ZDDP? I've heard this is a good oil that delivers a higher oil pressure.
                Paracetamol please.
                Micky
                  Ha ha.....nice one Micky!!
                  Sometimes you just need the 2 wheels!
                    Expect some groans on this - there are loads of threads on this subject, including a couple of recent ones and it seems usual protocol for the repeat cycle to be 6 months or more. The recent ones seemed to elicit some good, industry-guided, information so worth a search. ZDDP isn't so much a pressure improver, it's function is in limiting wear camshaft lobes to cam buckets.
                    Jonno
                      Not sure anymore. The European datasheet does not quote ZDDP levels or even mention ZDDP at all and direct questioning of Valvoline Europe did not elicit a definitive answer. As I have said on here before the formulation VR1 now sold in Europe has changed as evidenced by the Product Information Sheets published by Valvoline and is different from that sold a few years back and also different from that currently on sale in the USA. The USA version does have ZDDP at the levels thought to be required for flat tappet engines.
                      As Jonno says do a search for recent threads, I think it was something like "what oil do you use" - there was one which discussed ZDDP at length and also gave alternatives to VR1 - some quite a lot cheaper! (duck and run for cover)
                        FWIW I read somewhere that Duckhams Q 20w:50 is making a comeback........
                        David
                          And they are making it green again
                          https://www.duckhams.com/wp-content/...PDS-20W-50.pdf
                          Pete
                            Pete
                            But not unfortunately with enough Zinc in it to preserve our sort of engines, review the other threads under "What oil do you use" I'm still traumatised by it
                            Micky
                              The data sheet states ZDDP (Zinc) level optimised to protect classic engines. Sounds good to me. After all, oil companies donít tell porkies............
                              1974 Mk2, Carmine, ZF 4HP22 Auto, 3.45 Diff, Datsun Driveshafts.
