Zenith Stromberg carburetor overhaul
    Hi all, I thought there may be interest in seeing the before and after pictures of my restored carbs. I have a friend who specialises in such overhauls if anyone is interested in having their carbs properly overhauled PM me and I can put you in contact. The cost is lower than service exchange units and you get yours back. Thanks James
    This gallery has 3 photos.
    They look well
      Great job considering what they looked like before!
      Stag 2500S
      Jaguar STypeR Citroen C5
        This is what they had done for, those who have asked -
        The process is as follows:
        Carbs as delivered:
        Carbs removed from manifold and placed in a sonicating water bath with detergent to start the cleaning process:
        Next, they are completely stripped down to their component parts.
        The four aluminium castings (Carb body, dashpot, float chamber and cold-start device) are then bead blasted to remove any remaining dirt and corrosion:
        Carbs are then reassembled using new parts:
        • Spindle and spindle washers and nuts
        • Butterly and screws
        • Spindle buses
        • Needle valve and seating washer
        • Jet tube (set to original height)
        • Needle and needle adjusting screw
        • Float chamber ‘O’ ring
        • Float chamber gasket
        • Piston diaphragm
        • Piston damper fibre washer
        • Cold start device gasket
        • Temperature compensator seals
        • Dashpot screws
        All bracketry and associated fixings are cleaned and zinc plated
        Carbs completely reassembled and fixed to inlet manifold using new insulating spacers (if necessary) and gaskets.
          Dare we ask the cost?ğŸ˜
            The cost was £450, which given the amount of work seemed fair - just need to get the rest of the engine to the same standard
              James, I would say that is pretty good.
              Steve.
