external water pump
    external water pump
    Hi wondered if anyone makes a kit to fit ford externally belt driven water pump
    Try https://www.ebay.co.uk/itm/Triumph-s...36bb%7Ciid%3A1
    Jonno
      I have had mine for over 8 years still going strong no wear belt still as new.
          I had one of the first ones made no problems with it. Best upgrade that I have fitted to my Stag
          Cheers Glenn
            Cheers Glenn
            Same here, think I'll ask Steve if he sells the alternator bracket seperatey, looks far better than mine and also looks better than the one awards do!
            Weber, minilite copies, SPAX, EWP, MBHT
              I saw the alternator bracket yesterday on eBay ,and was going to ask the same question
                I have one of these kits, really good quality, easy to fit and works brilliantly, also good back up from steve when the bottom hose was accidently damaged after a radiator rebuild,Derek
                  Highly recommended, same as others, fit and forget.
                  Nigel
                  Nigel
                  1976 MK2 TV8 ZF - 4 HP-22 Auto, Hard Top Inca Yellow, Minilite Replicas, Stagdad Pump
                    So far so awesome
                    easy fit
                    best retro fit ever
                    every stag should have one
                    imoa
                      Totally endorse the kit and great support. I'm glad to see it's available to others again. Easy to fit too. Installed this kit in 2013 and done 14,000 miles with tweaks such as Wizard Rad, USA.
                      Tanya
                      Tanya: Brit in Canada
                      71 Fed Stag, TV8, Weber, ZF 4spd auto, EWP and crossed fingers
                        It's quite possibly the best upgrade you can do to your Stag.
