069 battery in a Stag?
    I might need a new battery and have been quoted a good deal for a Bosch 069 battery
    I have took some measurements and I will be going up to my garage shortly to see if it will fit
    l 252 x w 175 x h 220mm
    Has anyone used a 069 battery in their Stag?
    From PD Parts website
    You are looking for a 55Amp hour Battery that is sized as follows
    265mm long (10.5ins) and this should not be exceeded
    175mm wide (6.9ins)
    206mm high (8.1ins)
    Yours looks too tall
      I'm not familiar with the battery you mentioned but mine is a Bosch S4 027,fitted about 2 years ago by the previous owner. It's a very good fit in the engine bay.
        Just been Googling 069 battery and it came up with this,which also says S4 027 so it might be the one I have.....
        https://www.tayna.co.uk/car-batteries/bosch/s4027/
          thanks for all you replies
          I had a dead battery the other day
          its a Yausa 072 with a 2012 date on it installed by a PO
          anyway I have charged it up and surprise surprise it seams ok
          so hopefully I wont need a new one just yet
          I will prob go for a 069 next time maybe
            I recently fitted an 072 from Halfords. Perfect fit.
            '72 Manual O/d Saffron Yellow
              Just to clarify for me,what does the number actually signify? Is the 069 or 072 related to the physical size of the battery?
                Physical size, capacity and terminal layout.
                Pete
                  Thanks Pete. As I said previously mine is a Bosch S4 027 but I can't see any other numbers and don't really want to go to the trouble of removing anything just to find out.
