Side lights issue
    Side lights issue
    Hi when i put the side lights on only one side works ,then if I switch on the ignition both work ! bad earth ? any thoughts very welcome ,cheers Alex
    Cheers Alex
    Mk 1 White 19 ,MK1 Hood, Red trim TRV8 Minilite
    Sounds like bad earth
      If it only the drivers side, off side, that are on then it sounds like they are parking lights.
        It's the parking lights, ignition on ensures you cannot drive with only parking lights working.
        Danny
          Thanks for the ideas and info
          Cheers Alex
            If its park light you should have that on the headlight switch. It will have Park, off, side, main and fog positions. Park and fog I believe need to be pushed in then turned. Maybe a PO put a 3 position nob on the 5 position switch as the park position is after the off.
              A point of interest for some.... the very early pre production cars had a 3 position light switch, when the mk1's went into production the switch with a parking light facility was added.
