Paint colour code
    Paint colour code
    Can I just check with you guys that the correct paint code for Tahiti blue is 146
    Im getting my hard top refurbished and sprayed and the guys asked for the code number to mix the paint
    P
    P
    You are correct that code 146 is Tahiti Blue. There is a useful list here... http://www.stagbytriumph.co.uk/
      P
      If you want the hardtop to match the car then I would suggest getting them to match to the paint on the car. If it is original it would have probably faded by now so even if they make a batch that is a perfect match to the original when it was new it will look a different shade to the car now. If the car has been resprayed then all bets are off.
      Ideally you want them to spray a test piece first then hold it against the car, they won't like to do it as it is a real "faff" for them but they should understand the problem.
        +1
          Thanks good advice
          Il get it matched Il contact the guy and ask him to do it
          P
