crank shaft bearings
    I’m rebuilding my stag motor and have run into a snag can’t find the parts I need from usual supplier/rimmers. I am looking for crankshaft bearings, 30 thou over Main bearings, and 40 over rod bearings anybody know a good source for bearings? Thanks
    www.jamespaddock.co.uk
      Robsport have them listed. Looks like you may need to drop out some emails or get busy on the phone.
      https://robsport.co.uk/index.php/onl...ngs-%C2%96-030
      https://robsport.co.uk/index.php/onl...d-bearings-040
      Another suppliers that you might want to check
      https://socspares.co.uk
      etc
      Also worth checking on the thrust bearing, cheap enough to get a few different sizes in
        Hi just so you know it is good advise to have crank checked in that any regrind over 20 thou on Stag crank then crank needs tufriding or nitriding otherwise crank is to 'soft' to last,
          thanks guys.
