Toque setting for coolant drain plugs in the block
    I have just drained and flushed the engine, and on consulting the ROM cannot find a torque figure for the 2 drain plugs in the block. Does anyone know if it is specified somewhere, or what it should be? Thanks in advance.
    iirc they are brass fittings and tapered, it has been a while
    thread lock and not very tight at all I would guess,
      Thanks Richard. They came out with very little force, so I suspect that you are correct. They look brass, but with the naked eye, I can not see a taper.
        I think mine have fibre washers and I did them hand right so probably no more than 20 ft lbs
          Not very tight Nigel. Get some fibre washers from a diy store, I also put some PTFE tape on mine. Just nip them up.
            Thanks all
              I used to get a weep from the washers, so I fitted Dowty seals.
              '72 Manual O/d Saffron Yellow
