Hi all,
Have stripped the window regulator assemblies to freshen them up, which has bought two questions to mind - any thoughts as always would be appreciated.
1) why is there so much tension on the spring - roughly one revolution of the mechanism before fitting the motor/g'box into place. Is the motor not capable of raising or lowering the window (whichever i'm honestly not sure without checking) unassisted? If not, does it not then have to overcome any tension in the opposite direction?
2) I purchased new rollers and pins for the window assy, but the pins are shorter than the plastic rollers, so when you peign the pin over - the roller locks up. Surely the roller should "roll" in the relevant frame channel not be rigid, thus squaring off the roller?. Just like to confirm i'm not missing something here, as i've freed one up, haven't yet fitted the 2nd but am not convinced the spec of the design is correct.
Look forward to any thoughts
Gord
Gord
