What Size Rivets?
    What Size Rivets?
    Having fixed the rear plunger pin and spring to the bottom of the hood frame, I noticed the rubber seal is tired and torn in places. So I ordered the two new rubber strips to attach to the bottom of the rear frame. I now see these are held in position by what looks like very small rivets. See picture.
    I’m unable to source the rivets so need to source from the likes of B&Q. Can anyone tell what size I need to get? BTW Robsport don’t have any.
    Original rivets were 1/8" or 3.2mm, length about 12mm. You may find the holes have been opened out, so if they don't grip you could either drill new holes or use bigger rivets.
    Chris
      Thanks. I’ll acquire those you suggest and the next width up to be sure. It’s going to be a fun afternoon with a large sheet to catch the metal filings of the old rivets as I drill them out. Away for ten days first, though sadly with the daily driver.
