Gearbox mounts - caused vibration
    Just posted this in the 'crap parts' section, but in case you don't read that bit, I've discovered that a crazy vibration through the car that I've been chasing for months finally resolved itself when I put back my old gearbox mounts (only a couple of years old) instead of the brand new ones (from James Paddock) - maybe they were harder rubber or something? But yeah, was a nasty shake all the way through the car!!
    Sorted now... full story here:
    I did it!!! What an answer to prayer. The rumble is finally sorted! What was REALLY nice is that my mate Badger had popped over with his MGB and was present when I started Scarlett up vibration fre…
    Are the new ones poly?
    I had issues a decade or so ago with new cotton reel mounts falling apart after a few hundred miles. Even worse was the top hat and giant washers that hold the crossmember in place also dissolved! Now I had installed washers under the nut but it didn't take long for those washers to fail also. Luckily, I guess I found out because the gearstick suddenly shifted and I could no longer select 2nd or 4th. The gearbox was now hanging off the prop and exhaust mounts.. eek
    I would recommend +1 on poly cross member mounts, bushes and the biggest penny washers you can find as a fail safe.
    The cotton reel mounts, 10 years ago I did the same as you and popped the old ones back on, they are still there
      I seem to recall mentioning those mounts as a possible cause…
      2.
        Good to see Phil, enjoy your next rumble free run out.
          I've heard about these mounts. I have a few original used ones I keep. both my Stags are using old good mounts.
