Fan Cowl
This topic is closed.
    Fan Cowl
    The stagweber Fan Cowl
    Tests (using a smoke match) have proven that without a fan cowl, the fan only pulls cooling air through part of the radiator. Try it yourself, you might be surprised! Even the addition of an electric fan does not ensure that cooling air flows through all areas unless a suitable cowl is fitted.
    Now there is an upgrade specially designed for the Stag; the stagweber Fan Cowl.
    To upgrade your cooling system the stagweber Fan Cowl can be fitted easily in minutes, and this will immediately improve the cooling by pulling more air through your radiator. No electrics or moving parts to go wrong, and no maintenance required.
    What our customers said about the Fan Cowl:
    Hi Chris. received cowl assembly, fitted in no time at all, what a great mod and well made, complements the fuse box and header tank, improvements that bring a Stag up to date.
    It is however a nicely made bit of kit and I'm very pleased with it.
    The stagweber cowl works well, I would recommend them.
    See the full details and buy online at stagweber.co.uk
