Probably the easiest route to fuel injection on a Stag is to fit one of the new generation of EFI products which consist of a throttle body with a built in controller or ECU.
Holley sells the Sniper, which in 2 barrel form is the 2300, whereas Fitech sell a similar 2BBL one called the 39001.
These feature self tuning as you drive based on the signal form a Wideband Lambda sensor so there is no need for a rolling road session.
I have the Sniper 2300 fitted to my engine and have been running it for about a year now. I designed and 3D printed the adapter that it needs to bolt on to the Stag manifold.
