just out for a quick jaunt in the stag and noticed when i press the brake pedal there a loud hissing like as if i had a air line on there any ideas??? ot only happens when pedal is pressed , slight loss of breaking
theres a snake in my foot well!!!!!
I have the same issue although the servo test (checking for pedal drop when starting engine) seems fine. I've replaced the worn grommet on the one way valve so hoping it's that (can't test until I finish re-piping system though). I presume a leaking valve seal here would exhibit same symptons as the vacuum is lost?
Peter at LD Parts now sells new seals btw...
