MOT
    MOT
    Weh hey, passed again! I've taken it to the same 'old car friendly' local garage two years running now and the advisory items are competely different (only 400 miles between two MOT's). Last year advisory items were:
    Offside front suspension component mounting corroded
    Nearside rear suspension (door sill)component corroded
    Oil leak
    Headlight aim on bottom line
    I only changed the headlight bowl,and this year it's changed to:
    Nearside track rod end ball joint
    Offside track rod end ball joint
    Body has slight corrosion
    Both seats rock
    At least it got through
    good to see it passed ok, you can relax again for another year
      I got an advisory that my rear exhaust mounting rubbers were starting to perish, took them off and put new one's on but to be honest you could have hung a car off of them, ( old one's )
        Cheers Giles. It's like going to the dentist!
          Just had mine MOT'd.
          Advisories were:-
          Front Brake pads thin
          Gearbox output shaft leaking, but oil level OK.
          Front shock dust covers split
          As I don't do huge milages, no worry! Can wait til next year
          Only things this year - replaced rear wheel cylinders, replaced ignition switch to cure intermittent starting. (Rimmers sent wrong one twice so have rewired my imobiliser to suit)
          Changed oil, filter and coolant, raked out the block through the drains. Replaced my tyres at last for 205's giving a much more comfy ride.
          Thats it!
          Reading peoples troubles on here constantly makes me glad I have a good 'un! I probably paid a little over the odds originally, but what price reliability? Tester commented on low emmisions, even though it doesnt have to be tested, and lack of any corrosion anywhere.
          Enjoying driving the Stag!
          Al
            Des N wrote:
            Both seats rock
            Are they special ones then?
            Seriously, they all do.......
              I have just been onto the website to check on the date of expiery of my MOT as I am not at home, and I can find out online as long as i have the number from my old MOT DUH
              Why cant I put my reg no in and get it from that ? or am I missing something
              P.S. for the first time for about 20 years the handbrake actually works so I am looking forward to the MOT
              Standard stag thrashed and enjoyed, Nissan Murano ( very underrated, very thirsty, very fast)
                OIL Leak ???
                Wasn't sure they were anything to do with MOT
                  I should hope not I have been running a total loss system through the diff for about 20 years!
                    I know - I've seen your driveway!!
                    Peter f
                      Just called my garage and mine's just passed without any advisories! I had a very stressful morning waiting for that call I can tell you.
                      Not bad considering how many bits it was in over the weekend (including no brake system!)
                      but yes - puzzled about the advisory system - I had one last year for 'leaking exhaust' but this year none and I haven't touched it since last year. Weird... :?
                        Good news Toby
                        Of course the MOT test is subjective and advisories will always vary I guess as a result. All down to one persons individual opinion and even what sort of mood the tester is in:shock::shock::shock:.
                        Enjoy the next 12 months........
                        NIgel
                        Mk2 1976 Delft Blue with Beige Interior. TV8 and ZF 4 Speed
                          Great result Toby,
                          Nice feeling isn't it!!
                          well done
                          Peter f
                            fantastic feeling! thanks guys.
                            don't think I could have done it without this forum though!
