Hi, I got in contact with carl Dudash of Retrorockets, here is the reply RE: flamethrower coils and ballast resistors,....
Sukhdev,
If you are running points you should keep the ballast resistor. If you are running an Ignitor you can bypass the ballast resistor when running a 1.5 ohm coil.
Carl
Retro Rockets.
P.S from what is wriiten I deduce that since an ignitor is "electronic ignition" then the Luminition would not require a Ballast resistor either.
Sukh.
Just received the following RE: Luminition,...
Sukhdev,
The coil circuit resistance will be dictated by the Luminition system. I do not know what that system requires.
Carl
Retro Rockets
Sukhdev,
Carl
Retro Rockets.
Sukh.
Sukhdev,
Carl
Retro Rockets
