Hi All
Fitted new master and slave cylinders to the clutch today. The bite is barely above the floor which seems very odd considering its a brand new clutch. Currently the slave rod is set to the middle hole on the linkage.
Any suggestions on why the bite is so low? To improve it do I move the rod to the top or bottom hole?
Bruce
Bruce
. I bled the slave cylinder with it mounted in position. I will try again with it hanging loose so the nipple is at the top and see if that makes any difference.
