Heater pipe replacement
    Help does anybody if the steel pipe that joins the heater to the thermostat can be changed without removing the carbs? Its the pipe that runs inside the vee beside the cam cover.
    Thank you
    Hi
    You should be able to. I changed mine without removing the carbs but the engine was out of the car at the time.
    Bruce
      Did mine a few weeks back
      Just bend the bracket that secures it flat against the pipe with some pliars ( if your throwing it), it comes out then. I found the new stainless one went it easy too
        Thanks for the quick responce guys, shiny new stainless pipe now in situ
        Simon
