Eazybleed
    Eazybleed
    Hey ho, my Eazybleed doesn't have a cap to fit the Stag brake master, any thoughts ? Martin.
    I used the cap off a spare knackered master cylinder I had in the attic. Suggest you pick one up off ebay or a breaker like Just Triumph.
    Bruce
      Hi Martin.
      I have a spare cap you are welcome to. Just need to make a hole to take the easibleed fitting. Please pm me your address.
        i found that out a few months ago well the day before we went to the national, had to have 2 people do it.
          I alsoused a spare cap for mine as already suggested.
          My one had a small vent hole in it that I had to plug.
          Pete
            I did have one but it went AWOL some while ago. I drilled the hole through the vent hole. Martin.
              Hi Martin
              My father bought a kit and he then rang up the manufacturer and they sent him a lid for the Stag, so they do make one.
              Andrew
                Andrew S wrote:
                Hi Martin
                Andrew
                Thanks Andrew, trouble is I've had mine for about 20 years, I doubt if they'd send me one. Martin.
                  they do make a universal cap that just fits
                  mine looks like this
                  http://cgi.ebay.co.uk/Gunson-Multi-P...item53e00895e2
                  but drilling a old cap is cheaper
                  By the waydo not get brake fluid on the black nobbly stap as it makes it go soft!! (they sent me a new one after I did!!)
                    You might have a black knobbly strap mate but I haven't !
                      A good ol' milk bottle andrubber tube bled my brakes last week when I fitted s/s braided hoses.Cut a slit in the tube to act as a one way valve.
                      Sukh.
                        no need to worry about it going soft then
                          singapore stag wrote:
                          A good ol' milk bottle and rubber  tube bled my brakes last week when I fitted s/s braided hoses. Cut a slit in the tube to act as a one way valve.
                          Sukh.
                          When I changed the M/C last time, I found that pumping wasn't working properly so I had to pressure bleed, I'm expecting a repeat. Martin.
