i had to go to se trimmers this morning so it was mostly motorway ,on the way back cruising at 60/70 i came off to get on the A205 and stopped at a roundabout and noticed the oil light was flickering only on idle carried on to another roundabout and the same again by this time im thinking here we go, but then it stopped and didnt come on again not even dim on idle.has any one else had this it doesnt have a oil pressure guage.i checked the dip stick when i got back and it was about about 3mm under the top line...cheers dean
oil light
I've never had this happen on the Stag but have on other old cars I've had. My wife had a 74 Opel Kadette coupe and the oil light always flickered at idle - it even said in the owners manual it might do it and it's OK!As long as it doesn't do it at revs I don't think it will be doing any harm. However having said that if it didn't do it before then something's changed so worth looking into.
Bob.
Hughesy
After you have fitted a pressure gauge and if the pressure is below 10 psi, try fitting a new oil pump if you current one is old. Certainly cheaper than a bottom end rebuild. Craig
mike@thenook wrote:Hi,
I'd dispense with the useless temp gauge and fit a combined capilliary oil pressure and water temp gauge. Had one on mine for years and it is foolproof and accurate. MGB's used to have them!
It's pretty easy to fit and available from(among others) Rimmers.
deanoed wrote:cheers guys ive put it off untill now but it looks like im going to have to fit a guage i might even do the pump do you have to take the front exhaust pipes off to gain access...
