Are these good to put back in?
    My mate thinks these are worth changing, I am not sure. It is from one of the biggerclips on the funny shapped bar in the bottom of the engine. It is not the clips that are connected to the arms going into the holes.
    Its a shame Russ doesnt post anymore, as I am sure he would have a view on it and is the nearest to me if a good look is required to make a firm decision.
    Thoughts?
    another picture. Not sure which way around these go back on?
      BIG END BEARINGS and crank look F*CKED
      REPLACE THEM AND HAVE CRANK GROUND AND TUTRIFIED
      MACHINIST WILL SELL THE BEARINGS COMPLETE WITH CRANK
      IF YOU HAD LITTLE OIL PRESSURE THAN THAT IS PART OF YOUR PROBLEM
      ALAN
        ALAN
        MEANT MAIN BEARINGS
          Knackered. Seen worse, but those definitely need doing.
            That sounds a bit serious!
              Ditto
                have been doing a bit of googling and wondered if new shells and a bit of slick 50 might do the trick. Certainly cheaper but from these posts, I guess not
                  mine ran with less meat on the bearings and broken caps but the crank journals needed a light clean.
                  Maybe try running op engine with some oil in it..:P
                    You need to rough them up with an angle grinder to give them a key, wind some duct tape round them, and fill the sump with grease.....
                      Sawdust and the wifes chopped up pantyhose
                        Anybody remember Fullers Earth ? it worked in diffs Bad luck Graham, I know it's not funny. Martin.
                          Hey Hey! Welcome back Russ! How's things?
                            P.S. Welcome back Russ ! :dude: :dude: Martin.
                              All this time we have been waiting for Russ to come back and in he comes with such sound advice
                              Welcome back oh King of Green!
