:dude:hi guys, do anyone knows where i can obtain a rubber cap for the top of the fuel tank because it is begining to smell. paul
fuel tank rubber
Assume you mean the rubber bung type seal in the fuel cap. All the usual suspects do them. LD Parts have a very fast service. http://www.ldparts.co.uk/shop/shop.p...ccf8bebe471db6
However inclined to Russ' view that if you are smelling petrol it may well be leaking inside the boot. Check the connections and watch out for the little breather hidden at the top end of the filler pipe.
Hi Paul
If it is the seal in the filler cap it is an M.O.T. failure. As Russ says it could be a pin hole in the tank which can be repaired, you can get a kit called 'Petro patch'. It is also quite often the blanked off small rubber hose on the top of the tank that was intended for American market fuel return pipe that hasperished, fit a new piece of pipe here and bend the end over and secure with a small hose clip.
Bob
