From the stag.net archives
Pete
Here's the engineering description from the July 1970 issue of
Automobile Engineer:
"A 13 blade, 16-1/2 in diameter nylon cooling fan is driven directly
from the nose of the crankshaft by means of a Holset viscous type
coupling that limits the torque transmitted to the fan to 46 lbf-in
and the maximum speed to 2,500 rev/min. It is retained axially by a
co-axial bolt: the hub of the coupling, in turn, secures on the
crankshaft a Holset inertia type torsional vibration damper, and two
sprockets for the timing chains; the drive is transmitted to each by
a Woodruff key."
There is no mention of a lockup function as used in many other vehicles
to increase the fan speed when the radiator discharge air exceeds a
certain temperature.
a Woodruff key."
