Possible sticking valve?
    Went to the garage on Saturday to start up the stag and it started popping when the accelorator pedal was pressed to increase the revs. I suspect I may have a sticking valve so does anyone have any suggestions of how to test forand free a sticking valve without taking the heads off? Does Redex work in this case? Many thanks Staghoss.
    You could try a cylindercompression test.
      a good old fashioned vacuum gauge connected to the inlet manifold after the carbs will tell you all sorts of maladys
      sticking valve will show up as a regular drop in the needle
      alan
        Maybe this thread could be moved to the right area?
          Apologies for posting it in the wrong section. I did not realise it until too late.
          Thanks for the advise re the compression/vacuum tests-I will trythem. Staghoss.
            Not sure about the techy stuff, but moved to the correct forum
              Sorry guys, I'm a bit confused, what's he done wrong ? Correct forum ? :? Martin.
                I assume it was in the For Sale section?
