Brake Disk Thickness
    Hi all,
    does anyone know the thickness of the standard brake disk when new? And when should it be changed?
    Thanks Klaus
    1/2" (12.5mm)
      Richard B wrote:
      1/2" (12.5mm)
      Hi all
      that sounds strange to me. Why? I installed EBC disks last spring and measured now the9 year old standard disks from SOC Spares which I took off the Stag. They have worked ca. 70.000 km and still have a thickness of 14,1 mm. The unused rusty rim measures 14.5 mm. Is that stii the standard thickness of new disks today? I aske because I found already a suitable corner where I can throw my EBC grooved disks into when I have change back to standard. But thats another sad and costly story. I intend to use the old ones again although I have wire wheels.
      Meanwhile I found an old info from Mike Allen which he faxed (!) me 10 years go:
      the minimum thickness is alowed to be 0,528 inches = 13,41 mm.
      Any other figures or comments?
      Klaus
        These after market ones say 14mm max 12mm min so you could well be right.
        http://www.dcperformance.co.uk/cheap...scs/gd457.html
        Just measured my 2000 discs and they are 1/2" + 10 thou
          Yes Richard, that fits.
          Klaus
            I ask because I found already a suitable corner where I can throw my EBC grooved disks
            Mind if I ask why, what was wrong with them?
            I am considering an upgrade to the BMW 525 vented disc as supplied by Monarch. Then I can transplant the Stag set to my PI
              Richard,
              the problem was/is judder and wobble,I tried a lot of things to get rid of that but no positive result.
              I will report second half of Nov. with pictures when I am back from a longer holiday trip.
              Klaus
              PS. What does "PI" stand for?
                Petrol Injection
                I think
                  Klaus,
                  PI is the old Triumph term - Petrol Injection - for the fuel injection system used on TR6s (not North America) and 2.5PI Saloons.
                  FWIW
                  Peter
                    Peter Hills wrote:
                    FWIW
                    Peter
                    No Peter, I don't ask
                    Mfg
                    Klaus
                      Klaus,
                      FWIW - For What It's Worth
                      Peter
                        And Mfg? Mit freundlichen Grüßen (=with kind regards)
                        Klaus
