Thermostat
    Thermostat
    My Stag is taking a long time to warm up and is running cool, so I suspect that the thermostat is faulty. I have a very late MK2 Stag and the ROM staes 82deg., but LD seem to reccomend 88 deg. Which one should I go for?
    Hi Brian
    88 for winter seems to makesense as it will allow the engine to get warmer before it opens. Then switch to the 82 for the summer.
    Bruce
      Thanks Bruce. I was sort of thinking along the same lines so I'll call into JP for an 88deg one.
        Brian. I use an 88 degree all year round, including a trip to Le Mans in 35 degree heat this year, perfect!
          There is no need to change to a different temperature as the seasons change. The thermostat only controls the temperature at which the coolant is admitted to the radiator. The engine temperature depends on how much heat is generated by the engine and how much is taken away by the radiator. Fitting an 88deg stat is good in the winter, as it keeps the engine working around its ideal temperature.
          John.
            Thanks guys
            Jason - thanks for the info. Wow! 35 degree heat and people say that Stags overheat!
            John - thanks for the explanation, it has given me the confidence to go for an 88deg thermostat.
              Brian, that was sitting in roadworks too, with a 16" kenlowe and no viscous fan!!
              I was well impressed!
