Back from the Mot with a failll
    hi guys, yeah its come back from the test with a large fail... some welding on seat belt anchor point.. wipers not working but i know why that is....
    it would also seem my rear brake pipes are excessively corroded...
    where would the best place be to get these..?
    thanks
    Ben
    Ben my mate made me some brake pipes up the other month to length and i just bent them to suit,i think there copper seem better than the old steel type.
      Double post :/
        it says the rear one.... do i have to replace the whole pipe? cause i spent alot of time restoring the old ones and it would seem a shame to have to loose it... does it go from the servo all the way to the rear?
        thanks
        Ben
          Hi
          If the mean the pipe connected to the drum then this is only a short piece from the brake cylinder to the flexible pipe on the trialing arm.
          you can buy this bit them bleed the brakes.
          Advice - Grease the brake pipes each year than they will not corrode, clean off the smear the outside of the pipe with LM grease job done!
          Stuart
            stustag wrote:
            Hi
            Stuart
            Just a suggestion, use Kunifer pipe, it doesn't work harden like copper, or corrode like steel.
            When Aliens land in 10.000 years, all they'll find, is my stainless steel back bumper and your brake pipes, ask Russ, they may just be friends of his. Martin.
              Make sure your MOT tester explains exactly which one it is, although when you inspect them it should be obvious.
              I had an MOT failure on rear suspension bushes, so I replaced all the four bushes in the susp arms. When I returned for a retest he said no, it was the sub-frame bushes need changing!! He was wrong about that, but it was easiest to change them rather than submit a complaint. Needless to say I MOT at a different place now.
              My local motor factor makes up newbrake pipes to order while you wait. Just take the old one in for comparison.I did think about buying the kit to make my own, but its not worth it for the rare occasion when I would use it.
