Photo Tachometer.
    Photo Tachometer.
    Hi all, some kind soul started a short thread about the above, but sadly I can't find it.
    I've bought one off Ebay and blow me down, it works ! At long last I've been able to establish that my viscous coupling is faulty, not too chuffed about having to buy another, but now I know. A big thank you to said kind soul. Martin.
    Martin
    Just had a look for these as I didn't know what they were,found some on ebay but how do they work on the fan unless it knows how many blades it has?
    Cheers Steve
      The device comes with some reflective tape, cut off half an inch and stick it to one blade,it has a laser target light, point at the tape and it counts the revs, I checked it against a multimeter tach and it's quite accurate. Martin.
        Ah I see ,Would be good for quick comparisons between stags to see if a VC is failing,might have to have a word with Santa.
        What were your readings for your VC as mine seems to slip freelywhen hot but only spins 2 blades when cold which seems the wrong way around to me.
        Got a new VC ready on the shelf thanks to Bob H
        Cheers Steve
          Stagdad wrote:
          [quote]Ah I see ,Would be good for quick comparisons between stags to see if a VC is failing,might have to have a word with Santa.
          What were your readings for your VC as mine seems to slip freely when hot but only spins 2 blades when cold which seems the wrong way around to me.
          Cheers Steve
          Hiya, I'm afraid I didn't make accurate notes, but hot, at 2000 RPM the fan was reading about 850. Martin.
            Cheers Steve
            Hi Steve,
            The VC is supposed to follow engine revs until somewhere below around 3000rpm, where it will go no faster no matter what the engine does. I think 2850rpm comes to mind. The fluid inside shears at this speed.
              Cheers Steve
              Hi Steve,
              Thanks Dave /Martin,mine must be on it's way out I think as when hot it spins freely,Still don't overheat though.
              Cheers Steve
                Can anyone find the original topic on this subject? I would like to include it in the next Forum writeup in the mag.
                  Hi Dave,
                  Is it this one?
                  Al.
                    Arbman Al wrote:
                    Hi Dave,
                    Is it this one?
                    http://stagownersclub.mywowbb.com/vi...hlight=Viscous
                    Al.
                    Taht's the kiddie! Thanks Al.
