Warning: Trying to access array offset on value of type null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Notice: str_replace(): Passing null to parameter #3 ($subject) of type array|string is deprecated in phar://.../vb/vb.phar/string.php on line 3 steering pump - Stag Owners Club Forum
steering pump
    steering pump
    quite pleased with my self
    my steering pump is on the blink
    so i brought one from e bay for £3.49 plus post
    spent Sunday stripping down and re-plating the bracket and painting case
    also overhauled pump with all new seals
    alan
    alan
    another
      That looks brilliant Alan.
      Mine looks tatty and I've got another which I'm meaning to tidy up when I can. What did you do yours with? I'd be very pleased if I could make mine look as good as yours
        Very nice; looks like new.
        When are you going to finish the job and paint that bracket black?
        I'll get my coat
          all stripped to bare metal and de rusted in acid dip
          black etch primer , then two coats of satin black(rattle cans)
          brackets zinc plated
          nick
          p**s off:P
          alan
            Looks the biz Alan, very nice indeed, any probs with the pulley ? Martin.
              Apart from holding it steady with chain wrench , so I could undo nut
              then came off easy with three legged puller
              alan
                looks nice al do you do your own plating? ive looked at those frost kits and wondered.
                steve...............
                  yes I do
                  But I have a small industrial plant that i set up myself
                  cant vouch for kits sold by frosts
                  As I use it to replate the gauge cases
                  Alan
                    Me too - anyone with any experience of them?
                      main problem with these i think are
                      1
                      the price
                      2 no rectifier supplied
                      and difficult to plate on battery voltage unless you put some resitance in using light bulbs
                      chemicals are easily obtained
                      boric acid,zinc chloride,potassium chloride,zinc carrier and brightener and
                      zinc anodes
                      gateros plating is cheaper than frosts
                      Gateros Plating Ltd | Specialists in home electroplating, electroforming, and metal treatment kits.
                      maplins for rectifier
                      hope that helps
                      alan
                        cool, that looks like an interesting bit of kit to have in the tool box! How good is the 'Replica' Chrome? is is robust enough to withstand the elements?
