Quarter light seals
    Quarter light seals
    I'm thinking of putting a new pair of quarter light seals on the Stag and wondered if anyone has done this yet? Are they difficult to fit? I think mine are causing a fair bit of wind noise as they are very perished, although they don't leak!
    Brian, I have started this, I've only gotten round to doing the drivers side. Not too hard to do. Take the door card off, 3 bolts hold the quarter light winder, open the quarter light and pull it up. Mine was quite tight, I soaked it in WD40. The new seals are a perfect fit!!
      Hi Jason,
      many thanks for that, it is a lot clearer now!I think I'll give it a go over Christmas. Stag parts which actually fit! Yippeee!
        Brian,
        Check this out. Found it in the member's section under SOCTFL.
        http://www.stag.org.uk/UserFiles/doc...structions.pdf
        Regards,
        Thom
          Thanks Thom.
            Brian let us know how you get on, this is one thing that really needs doing on mine but at £40!! i thought it can wait but then again if its easy to do i can do it whilst it being welded ......
            where is best to buy them from??
              I was going to buy mine from Paddocks as they are only 9 miles away!
                They are SOCTFL parts, Ben. So they should be the same price from all the usual outlets (EJW, JP, RB, Robsport, LDparts).
                  Brilliant it wasnt so much the price, was more best fit but as they all come from SOCTFL then i assume they will be spot on
                  thanks
                  Ben
                    I did mine last year and if I can fit them anyone can! Just make sure you don't muddle them up - fitted the driver's side and then realised I'd fitted the near-side one! The air was blue I can tell you!
