Powder coating hood frames.
    A few observations when tackling this job. ALWAYStakethe frame apart completely, do whatever rectification needed to straighten or weld, then have it powder coated. Then it can be re-assembled, having cleared the threads with the appropriate thread taps. It is most unwise to do it `the easy way' & have it coated `in one piece'.
    Apart from getting poor coverage due to overlapping construction you will almost certainly have operating problems!
    For those of you un-familiar with this process may I explain. Paint in powder form is sprayed onto the metalwork @ very low pressure under a negative charge. This attracts the powder to the metal. The item then goes through an oven @ around 200oC, whereby the powder gives in & is fused to the metal. That is why it is so hard-wearing. Unfortunately, the powder doesn't differentiate between the main metalwork & the poor little shims that are on every joint which are supposed to revolve,some as thin as 1/32in. They just bake together & need a hammer & chisel to separate! Believe me! Also, under the extreme heat, any rust particles on the bolts will proliferate, (rusting is heating), they will no longer allow parts to swivel on them. Instead,quite often,they force the movement of the joint through the securing thread, either stripping it or shearing the bolt!
    If the bolt heads & nuts are all nicely powder coated then the frame will have been coated in one piece! I hope this is of value to anyone about to tackle this job.
    Vames. :dude: Merry Christmas.
    Did mine this way. My mate had a stag so we could use his hood as a guide to put it back together again.
      make sure you use polyester on exterior parts
      Epoxy powder coating is recommended for use in interior situations where toughness, chemical resistance, and good mechanical resistance properties are essential. The protective properties of epoxy powder coatings are not impaired by exterior exposure, but chalking will occur progressively.
      For use requiring ultimate heat stability and outside durability polyester powder should be used.
      I had stove enamel and powder coating company for twenty years
      Alan
