Warning: Undefined array key 6236 in phar://.../vb/vb.phar/library/content.php on line 2
Warning: Trying to access array offset on value of type null in phar://.../vb/vb.phar/library/content.php on line 2
Warning: Trying to access array offset on value of type null in phar://.../vb/vb.phar/user.php on line 1
Warning: Undefined array key "online" in phar://.../vb/vb.phar/library/content.php on line 2
Warning: Trying to access array offset on value of type bool in phar://.../vb/vb.phar/library/user.php on line 2
Warning: Undefined array key "reputationimg" in /home/socforum/public_html/forum/includes/vb5/template.php(404) : eval()'d code on line 72
Warning: Trying to access array offset on value of type null in /home/socforum/public_html/forum/includes/vb5/template.php(404) : eval()'d code on line 72
Warning: Undefined array key "reputationimg" in /home/socforum/public_html/forum/includes/vb5/template.php(404) : eval()'d code on line 77
Warning: Trying to access array offset on value of type null in /home/socforum/public_html/forum/includes/vb5/template.php(404) : eval()'d code on line 77
Warning: Undefined array key "birthday_search" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "joindate" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "privacy_options" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2
Warning: Undefined array key "lastactivity" in phar://.../vb/vb.phar/library/user.php on line 2
auto / manual change over -
Stag Owners Club Forum
Hi, I've two T V8, srs 1, one auto box, one manual. I need to swap the engines over [obvious really -- I'm married, one has to do such things] QUESTION IS any snags, problems hints on this. To be done out of car. Foxy
There is a bush in the end of the crank that will need adding or removing depending which way you are doing the swap, also watch out for the spacers on the flywheel of manual/ auto, they are different and if you get them the wrong way round....... I dare say Rubce can enlighten us hereAlso early cranks have 4 bolts, later have 6 though I believe this is not a problem
