Door arm rest securing
    I've just finished replacing my Mk II door cards following Bob Heritage's method. It was quite time consuming however I'm very pleased with the endresult. Thanks for the "how to guide" Bob.
    When I removed the doorarm reststo carry out the job, I noticed there was a hole under the arm rests that corresponds with a hole in the door card and trim but had no screw or bolt in it. This is in addition to the 3 screws that hold the armrest from behind the door card and the bracket which holds the puddle lamp.
    This was the same on both the passenger and drivers side. The hole is set into a recess in the bottom/underneath of the arm rest half way along just as the arm rest curves.
    I have checked the Triumph parts book and also the Rimmers catalogue and can find no reference to the bolts/screws that should/may fill the hole or any securing device that is behind the panel.
    My thoughts are that it may be a left over from the Mk I and redundant on the Mk II door arm rest.
    Can anyone help me out please?
    Thanks and regards,
    Raoul
    Raoul, You should have a large screw here which provides a secure anchor for the door pull. It goes right through to the door framing. Can't remember whether it screws to the metal or to a nylon socket. If you have a workshop manual you can see it in the DOOR TRIM PANEL Remove and refit section. Mine is an early Mk 2 with Mk 1 doors but the door pull really does rely on it so I can't see why it might have been discontinued.
      Brian,
      Stainless self tapping screwand washer are now fitted, thanks very much for your reply.
      regards,
      Raoul
        What is the Bob Heritage method you mentioned in this post?
          G'day Steve,
          If you read the thread belowyou'll find Bob's post.
          http://stagownersclub.mywowbb.com/vi...ght=door+cards
          regards,
          Raoul
