Hi all carpet specialists,
I started to fit new tufted Aldridge carpets. First part was on the LH (drivers) side sill. No problem to fix the long part under the small chrome rail. But under the hinges(A- post) it does not fit at all (see pic).The problem is to bring a 2 dimensional carpet into a 3 dimensional shape. Did I make a mistake or did I start at the wrong end? The 36 year old carpet was obviously preformed at the A-post corner as they are on the two seat supports. Is heating the carpet rear side with a hot air gun the solution?
Up to now I have only glued 25 mm of the rim to the metal and it may look better after glueing the comlete flat vertical section. But there will still remain some ugly creases.
Aldridge was again and again recommended on the forum so there should be a lot of experience from other Stag drivers and a solution for the described problem. Please help and let me know how I shouldcontinue. Thanks in advance.
I will be out of town until Friday noon in case you have any questions.
Regards Klaus
Regards Klaus
