Looking to fit the seals Ian (Milo) very kindly gave me.
I'm after a bit of guidance as to how the control valve comes apart ,It looked to me that after the circlip was removed above the oil seal in the picture below the guts of it would come out from the top but they won't .So I then removed the unit and at the other end is a circlip to retain the bearing ,on removing this circlip I thought the shaft would then tap upwards ,again no:?.The rom is very sketchy on this and there are no pics of which way the inards should be coming out.
It simply says "Carefully press or tap out the pinion shaft andwithdraw the spool sleeve and pinion assembly from the housing" But from which end ????????
I'm normaly pretty good at working out whats going on but this one has got me puzzled and I don't want to damage it .
Thanks in advance Steve
.Once again thanks to everyone for their help. Power of the forum rules
