I've had the usual click problem for a while now but it has gradually got worse and now when I turn the ignition nothing happens. There is no dimming of lights etc when trying to start, so I believe my ignition switch may be at fault. My ignition switch does not automatically spring back when started and you need to do it manually or starter would just continue turning(when it did work). I think this is a separate issue but may be worth mentioning just in case. It was never left on in such a way that it would burn out the starter.
On removing the ignition switch, I see the wires are numbered 1-5. #1 is brown, #2 is white, #3 is red/green, #4 is red and the white/red wire connection is #5. On turning on the ignition 1st phase, I have power at #1 connection. On turning the ignition to phase 2, then 12v is also seen at #2 and #5 as well as #1. On turning ignition to the next phase, as in turning the starter, then the 12v disappears from brown #1 and stays on #2 and #5. Nothing is ever seen at #3 and #4.
Can anyone confirm if this is ok? I would have thought the 12v supply through the #5 white/red connection to solenoid would only be supplied when trying to turn starter?
Thanks in advance of any advice.
