I'm going down the powder coating path with my front suspension and I understand that they heat it up to something like 200 degrees.
Question 1: Has anybody had any components powder coatedwith bushes or other rubber components still fitted ? To be on the safe side, I'm removing everything that's rubber as I don't want it to melt :shock:
Question 2: In dismantling thefront strut, I have taken out the damper insert, by knocking out the peening and unscrewing the top retaining collar- for the reasons above. I have an ordinary system and the leg has quite a bit of oil in it. As I extend and compress the damper, the oil is ejected from the bottom and its damping capabilities reduce as all the oil is ejected.
So, when I reassemble I guess I'm going to have to refill the strut with oil and my questions are: what sort of oil and how much?
There's absolutely nothing in either the ROM or Haynes about replacing the insert as far as I can see :?
All advice gratefully received.
