How was it for you? As good as it was for me, I hope.
The first day I felt brave enough to take advantage of a bit of sunshine. My Stag on the drive way, both doors wide open, now there's room to actually achieve something that can't be done in the garage.
Work done:
:Front and rear chrome (stainless?) light panel surrounds fitted, glued where necessary, and 'grouted' with dum dum.
:Attempted to fit door top seals to hood frame channels, see sketch, I assume 'B' should be inside of car? Awaiting confirmation before continuing.
:Adjusted hood frame position to suit seals.
:Renewed vinyl trim to rear seat back support bar and water gulley surrounds.
:Re trimmed the top section of both cubby panels.
Feeling rather pleased with myself.
Feeling less pleased that the window frames in the doors or maybe both entire doors have to be raised to achieve a flush top edge with the top of the 'B' Post. All my gaps are parallel and I recall that the window frame was adjusted to as high as was allowed. Hmmm.
That going to have to wait for another good day.
Regard
John4D
Work done:
Regard
John4D
Martin. PS, I used Swarfega, made it much easier, Waxoyl would do the same.
