I replaced all the plugs in the left hand head unfortunately they are leaking a bit with no signs of stopping, I know i could put in some sealer but i also have a small oil leak at the back of the head to block all this work was done when I overhauled the head so i am not happy with the oil leak and wil pull the head back off. I need to do a bit more checking to find out why it leaked also I will use some Wellseal in that area to seal the surface joint.More than likely I will have to take a cut in all of the bores where the plugs go to clean up the sealing surface. I should not have to cut much from the bore and I can make aluminum or brass plugs at work so my question is do you think this would work? or should I source the next available size plug and machine the head to fit this? Any body tried this?
Cheers Stuart
1970 MK1 LHD
Cheers Stuart
1970 MK1 LHD
