The rear offside exhaust pipe has always been very close to one side of the cross member as it travels through the hole. This has always caused a noise under acceleration and deceleration. I replaced the bushes etc on the hanger recently and refitted by wedging a piece of wood in the hole of the cross member on the side that it was closest too before tightening everything up. My first attempt was excellent, with no vibration under load but there was just an exhaust resonance at 30mph and 60mph which you could drive through. Thought I would have another go at realigning and now its back to how it was. The positive thing is, I know what is causing it.
As you look from the back at the offside cross member, the pipe is pulled towards the diff and when tail pipes are fitted, upwards.
I have just removed the tailpipes, and the pipe section that runs across the diff and the pipe sits perfectly square in the cross member hole and when its also in the hanger, although not bolted up tightly.
Put it all back together again and there is an instant pull to the left
My tailpipe hangers appear to be in the right place and I am now wondering if the intermediate pipe GEX 1435 is too short of the wrong shape. Its stainless so I cant really bend it.
Tempted to buy a mild steel intermediate pipe so that I can bend when fitted
I know that I can tighten up the hanger but when everything including tailpipes are fitted, there is a lot of tension there and has always been there.
Has anyone had a bad intermediate pipe that is too short or badly shaped?
And why is the exhaust bracket and hanger so close to the handbrake cable tube as I must have about 1/8 gap, if that when bolted up.
Any advice or suggestions much appreciated
Andrew
Andrew
