Who's changed their J Type overdrive solenoid?
I'd looked in the ROM and I just couldn't believe what I read Basically it said, disconnect the wires; use a 1" AF spanner to undo the solenoid and then screw the new one in. It even said it didn't matter which way round the wires went. Well, I was even on the point of posting something like 'Is this the easiest job ever on a Stag'.
I should have known better What it didn't say was that, because of the positioning and the limited amount of space, your 1"AF spanner mustn't be any thicker than about a tenth of an inch, nor that it can't be longer than about 2 1/2"
Luckily I found an old 1"AF spanner and, even more luckily, I bought myself a new bench grinder a couple of weeks ago so I was able to make my special Overdrive Solenoid spanner. Heaven knows what I would have done without the grinder.
If anybody is replacing theirs then contact me first and you're welcome to borrow my special spanner
 Basically it said, disconnect the wires; use a 1" AF spanner to undo the solenoid and then screw the new one in. It even said it didn't matter which way round the wires went. Well, I was even on the point of posting something like 'Is this the easiest job ever on a Stag'.I should have known better
 ) It's not a fancy one with a nut welded on it but I found it easy to get the ring of another 1" combo around it and that gave enough leverage to undo the solenoid.
