Hood frame fitting problem
    Hi
    I am in the process of fitting my hood and frame to my car and it will not go up or down without jamming and need some advice or photos of how the torsion springs fit in relation to the mechanism as the previous owner had dismantled the frame. I have read in the haynes manual that I might need a "jig bolt" are these available from anyhere and what do they do?
    Is there a set routine of adjusting and fitting the whole assembly?
    (PS the hood is already on the frame)
    Cheers Glen
    Hi Glen,
    there is a good picture of the jig bolt with measurements in
    the stag repair operations manual page 76.61.08,
    hope this helps,
    Martin.
      hi
      Where would i get that book from? is it available on the net as a pdf?
      Glen
        pm sent to stagmoneypit
          you don't need the jig bolts you have obviously assembled the frame wrong . i have had mine off twice and never used jig bolts if i can get to the garage tomorrow i will post some pictures
          john
            e-mail sent to stagmoneypit
