Hello everybody,
Last week I got the Stag out from her hibernating place. She started immediately when cold.
After I had driven her for a while and tried to start the engine when hot, this only worked with the choke half pulled.
I know that I have a slight flooding problem with obviously sticking needle valves on the Strombergs. So the carbs run (too?) rich.
Can this be the reason?
If I manage to install the HIF6 carbs on Saturday, I might have solved all those problems. If they do not fit, I will at least replace the needle valves.
Any advice is highly appreciated.
Kind regards,
Dieter.
Kind regards,
Dieter.
